So yesterday I build my first ryzen system, and was very happy, it posted, installed fresh win 10 home, all drivers, even latest chipset from amd on it and everything seemed to work but then I noticed 3 problems:
1. My cpu core clocks/voltage jumping like crazy by just moving the mouse from 3,2 to turbo 3,60 every time
2. When I put pc to sleep mode it weirdly gose to sleep, then I try to wake up him and he stays whit black screen and then just restarts rondomly(two times) and only then turns on
3. My bios screen sometimes is too large for my screen in rez, my monitors is 1080 p, but bios gose in that 1280x728(I think) rez
I tired to adjust power plans(disableing fast boot, tuning on balanced mode, and other basic stuff to try to fix) , but it didn't help me.
So any suggestions for me? Maybe need to replug all cables, ram, gpu?
Tnx for help :)
My system: ryzen 5 1600 af, asrock b450m-pro4(out of the box came whit newest bios, supports  ryzen 3d gen), sapphire rx 460 4gb oc gpu, g. Skill ddr4 16gb 2666mhz ram, kingston 240 ssd,  fps si series 700w psu,
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1153047-new-build-ryzen-system-problems/
1. check memory installation, clean the memory and replug properly.
2. same as above.
3. some monitors do that, the screen won't fill up. dont bother, if your mobo comes with a bios screen program do it from there (inside windows).
2. same as above.
OK I'll try to reseat them, should I try to put them in different slots? Currently in a1and b1 slot.
I'll check if it has that program
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Look in your mobo manual which slots to use for ram if you only use 2 dimms, because most boards usually use a2 and b2 for dual dimm operation. Yours might b me different so look it up just to be sure
OK I will
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
6 minutes ago, Bayron said:
OK I will
173294458_ScreenShot2020-02-06at11_03_04PM.thumb.png.0484c2c53e898adedf63c096fa786ede.pngHeres a chart from the owners manual of your motherboard. Mephi00 was correct, if only 2 sticks of ram are being used, you want to put them in slots A2 and B2.
On my ryzen system, i frequently swap odds and evens without any effect.
I don't know if this still a thing.
Changing ram slots did not fix the problem 1 and 2, but it seems to have fixes bios screen to normal
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Tryed every power setting, reseting ram gpu cables but the problems are still there(bios worked good for couple times the went back to bad rez) ahh I guess I'll try to reinstall windows
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Clean install of windows did not fix sleep issue, that's the main problem right now
Other two is kind ok, cpu works normal now and bios meh, it can stay like that
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
So yesterday I build my first ryzen system, and was very happy, it posted, installed fresh win 10 home, all drivers, even latest chipset from amd on it and everything seemed to work(Tryed ac origins and everything worked, was stable) but then I noticed a problem:
When I put pc to sleep mode it weirdly gose to sleep(screen flicker) , then I try to wake up him and he stays whit black screen, fans trun on, store hdd turns on and then just restarts rondomly(two times) and only then turns on
 Allready try troubleshooting, power plan change, hibernate mode trun off, fast boot turn off, but it seems nothing helps.
My rams are in a2 and b2 slots and gpu in pci gen 2(first slot).
Any suggestions?
Tnx for help :)
P.S made fresh reinstall today but same problem
My system: cpu ryzen 5 1600 af, mb asrock b450m-pro4(p3.60 bios) , rx 460 4gb gpu, kingston 240 ssd, seagate barracuda 1tb hdd, fps si series 700w psu, g. Skill ddr4 16gb 2666 MHz ram.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
So are you saying that you newly built system works but there is a problem with sleep mode where upon waking from sleep it instantly crashes, restarts twice befor successfully restarting, and you have made several attempts (vaguely detailed) to try to solve it?
Sleep or hybernate.
1. Sleep : turn off all except memory.
2. Hybernate : everything turned off, memory dumped to the ssd. Turn on, memory dump back from ssd.
If 1, then maybe problem with your memory.
If 2, maybe problem with the ssd.
Look in the event viewer and see if you see any errors.
Look into the Windows Sleep and Hibernation settings, make sure there is enough disk space allocated to Hibernation/sleep.
Also, in the bios, check for the settings for Power On after loss of power, that sometimes screws up things as well.
Yes, system when turned one is stable, tryed heavy lods, everything is good on cpu boost and gpu power
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Ok.  There are people here better qualified to specifically address this.  I’m mostly just trying to facilitate so that they can get right into your problem.  I’m being low level support.  You need a higher level than me.  My knowledge on this one is only general and I can only make guesses.  My best guess is that windows does laptops as well as desktops so there are a bunch of different available hybernation and sleep levels and it may be set to one your system doesn’t support.  Might do to get into the specific sleep and hibernate levels and see what exactly you are set for.  Just a guess though.
OK tnx I'll check some stuff in those settings
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Should I tur it on? It's off rn
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
3 hours ago, The_Geek said:
This would be in the Bios and Windows settings... so you probably would have to turn on the PC... but why would you not want to turn on the PC?
I mean that setting in bios ?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
Sorry, misunderstood it.
Well, that is a personal preference.
On my media server, I have that setting to ON, as I want the machine to boot back up after a power failure and the UPS running out of battery power, as I have loaded some of the things as services, and they start automatically.
Try it both ways and see what you want and what works...
Did you find anything in the event viewer?
Also restate the issues you still have, things went muddy with so many responses.
Found solution, i can put pc to hibernate and then its works fine, wakes up ok like from hibernate it should.
pc works fine, made stress test on cpu and gpu, temps are ok, voltages are ok too.
so i get these errors and warnings after i put pc to sleep:
i will attach these txt files
those after time are the newest errors and warnings i get after sleep mode wake up(x2 restart)
111.txt 222.txt 333.txt 444.txt 555.txt
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
2 hours ago, homeap5 said:
In power settings find "allow hybrid sleep" and disable it. Or change some bios settings related to power state when sleep. It's just guessing, I'm not using sleep.
Everything is off and still have this problem
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
This is another plague i have been noticing, since 4 years ago i had a huge problem after PC went to sleep and never woke up.....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
