cheapest 4k monitor $560
prolemur
TN 30Hz, NOPE
I'd prefer an ips 2.5K @ 60Hz for the same price
TN isn't the problem.
30Hz is the real problem.
I only read the TN part, not the 30Hz
I don't think the tn panel would be that bad guys but this wouldn't be a gaming monitor probably a productivity monitor or content consuming
This is a very low quality 4k tv not a monitor
well it was the first thing that came to mind. I dont recomend it but you wanted 4k under 500
Let's help the professional market with 30hz TN panels, hurrr.
Mobo: Z97 MSI Gaming 7 / CPU: i5-4690k@4.5GHz 1.23v / GPU: EVGA GTX 1070 / RAM: 8GB DDR3 1600MHz@CL9 1.5v / PSU: Corsair CX500M / Case: NZXT 410 / Monitor: 1080p IPS Acer R240HY bidx
At the end of the day, I guess you're getting what you pay for...
I think it's more the high price and lack of IPS that drives them off, not the TN alone.
If it were like $400 - $450 and TN, I'd say that's more than acceptable.
Nearing the $800 mark (at regular price) I expect something a little better.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
They have no competition driving the price down, I'm surprised its this cheap to begin with.
What really is there other than games that run at more than 30 FPS? I've always been under the impression Youtube, Netflix, etc are all 24 FPS. Lets face it, the monitor was never intended for gamers.
30 Hz
I bet you could OC it to atleast 50Hz, assuming you get a good one.
Where do bad folks go when they die?
They don't go to heaven where the angels fly
They go to the lake of fire and fry, Won't see them again 'till the fourth of July
its not likely. dell monitors have never overclocked well in the past.
Try setting your monitor to 30hz and try it. Mouse movement is laggy and weird. You can get used to it but its kinda hard to use.
i7 4770k, 16GB Corsair Vengeance
Gigabyte z87, Phanteks Enthoo Primo
7970
The panel itself can do 60hz (should be the same as the one Asus will use) but the inputs don't have enough bandwidth. I think the most you can do over displayport with out MST is going to be around 40hz.
7970
Displayport does support 60Hz 4K.
Display port MST does but the dell monitor doesn't support that, it's just regular display port.
7970
Dell fucked up really really bad this time. Though it claims to have 1.073 billion colours but with a tn it makes no sense. Also, 30hz... 30 fucking hz.
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
Displayport does, display doesn't.
ASUS ROG G75VX
