So I recently saw a long finished Kickstarter campaign video for this thing called the Hypercube. Problem is, they want $400 for the 15" version. So I decided to build my own.
The led strips cost me $54, the plexiglass cost me $70, the one way mirror film was $8, and there was about $9 worth of cedar lumber. I'm sure the commercial version has far fancier software running it, but for $250 less, I think mine turned out great!
https://linustechtips.com/topic/1152012-i-built-a-thing-today/
Congrats on building a cube with lights in it.
Ryzen 3600 4.33ghz . CM Hyper 212 Turbo. MSI X470 Gaming Plus Max. Crucial Ballistix Sport LT 3200 @ 3200 CL 15 (OC). Powercolor RX 5700XT Red Dragon. FD Meshify S2. Crucial P1 M.2 1TB. Corsair Vengeance 650W 80+ Silver.
Core 2 Duo 3.4ghz . WenjuFeng cooler . ASUS P5G41C-M LX . Crucial 1066mhz 3GB DDR2 . Gainward Golden Sample HD 4850 . Coolermaster Elite 430 . Seagate 160GB IDE 7200RPM . BeQuiet System Power 9 400w 80+ Bronze
https://linustechtips.com/topic/1152012-i-built-a-thing-today/#findComment-13268953
Cool!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1152012-i-built-a-thing-today/#findComment-13268969
i thought that was a pc case for a min and i was like "damn, im actually considering spending $400 on a sparkly cube..." then i saw that it was for lighting.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1152012-i-built-a-thing-today/#findComment-13268971
Imagine spending just $5 for a light bulb though... that's for normies!
https://linustechtips.com/topic/1152012-i-built-a-thing-today/#findComment-13268974
*** Thread locked ***
This type of content is better to leave for your Status updates. Or if you write whole story about building it, the Hobby Electronics section is way to go.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1152012-i-built-a-thing-today/#findComment-13269016
Guest
