Hello all. I am trying to overclock my 7700k. I am getting very high temperatures when stress testing using IntelBurnTest v2.54. At idle I get around 33C. Using the standard Stress Level, under load It spiked very quickly to low 90's on all cores so I stopped it. I did not touch the voltage at all so I am wondering why I would get temps so high. Never used this software before so I am wondering if I should use something else or if there is a problem  with my computer.  Thanks.
Unsure what power supply to pick?
Check out my HTPC build.
Quote me/others so we can help you
Comic sans is the best font
https://linustechtips.com/topic/1151635-extremely-high-cpu-temps-intelburntest/
A program that simplifies the usage of Intel Linpack. Linpack by Intel is an extremely stressful program that will put even the most powerful X86/X64 CPU in the world at its knees. Load temp under Linpack will be up to 22*C higher than the competing software Prime95.
Sounds like its made to get your cpu very hot i never used that Programm so i cant tell u if thats normal but 22c higher then my prime test for me would be around 100+ so ehh :D
