My first pc.
Solved by Fasauceome,
1 minute ago, kiksaa said:i wont get that case i just added it and the ssd so its not empty i got another case its mid tower and it supports atx,so adding the gaming plus version of the motherboard then
Should be good to go then, it's quite a solid build. Hopefully you upgrade the RAM sooner rather than later, but until then, you should look up how to overclock infinity fabric. It can improve performance plenty.
