CPU help
Go to solution Solved by THraShArD,
I think thermal monitoring technologies is a feature for overheating purposes, and not about physically reading the temperatures.   It's usually all read by the Motherboard.
Sometimes if you plug in the CPU fan in the wrong port, some software won't detect the Fan RPM speed, but you should still get temp readings
I have an old i5 660 and it doesn't have the thermal monitoring technology and thermal paste so how do I know it's temperature.
I played many games like Far Cry new dawn, far cry 5, assasin's creed origins and never got a blue screen.
Should i do something about it?
https://linustechtips.com/topic/1151434-cpu-help/
What software did you try to check its temperature?
Desktop benching:
https://linustechtips.com/topic/1151434-cpu-help/#findComment-13264421
The i5 660 has a temperature sensor though, have you tried HWiNFO?
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1151434-cpu-help/#findComment-13264441
The BIOS will have the temps.   Not sure if it's still free, but if you get a hold of SiSoft Sandra, that will give you readings in Windows
CPU i7 4960x Ivy Bridge Extreme | 64GB Quad DDR-3 RAM | MBD Asus x79-Deluxe | RTX 2080 ti FE 11GB |
Thermaltake 850w PWS | ASUS ROG 27" IPS 1440p | | Win 7 pro x64 |
https://linustechtips.com/topic/1151434-cpu-help/#findComment-13264534
https://linustechtips.com/topic/1151434-cpu-help/#findComment-13264551
8 hours ago, Budget gamerXD said:
When I went on Intel's website it said no thermal monitoring technology.
The program I used is cpu-z or gpu-z
neither of them can do it on any CPU. Use HWinfo in sensor mode or Core temp
Desktop benching:
https://linustechtips.com/topic/1151434-cpu-help/#findComment-13265341
