White VGA Light On, But Everything Appears to Run Fine
Solved by Husky,
If it is running fine then you have nothing to worry about. The light staying is probably just due to a bug in the UEFI or something. You could test if it stays off if you disable Windows Fast Startup (under Control Panel > Power Options > Change what the power buttons do).
Ha-Satan ·
Posted in Networking0 -
1
Beenlucky1 ·
Posted in Cooling3 -
Biermax ·
Posted in New Builds and Planning10 -
potatonut ·
Posted in Troubleshooting3 -
9
4
ManemeJeff ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
