Can someone find thisThermaltake USB to 3 Pin aRGB cable?
Hello guys!
I'm looking for a single USB to 3 Pin rgb adapter like from the Thermaltake Pacific R1 Plus  to connect it to the Thermaltake Sync Controller TT Premium Edition. I want to plug in some Thermaltake Pure Plus Fans from their AIO which doesn't came with a usb connector cable for the rgb.
Can some please find this cable on the internet because I don't find it.
Here are two pictures of this cable I'm looking for:
2 hours ago, SkilledWorm said:
Hello guys!
It's proprietary to TT so you would be best to directly contact them to see if they can send you some.
8 hours ago, SkilledWorm said:
Hello guys!
looks like a 9pin internal header (same as usb i think) to my guess 3 pin jst-sm connector
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
