Need help to upgrade my GPU
Solved by Fasauceome,
Just now, VImal said:Upgrading psu and ram is not a problem.But i m worreied about the processor. But also i needed the best gpu which can run on my system. Some guys mentioned about bottlenecking the gpu if i use high end cards.
Bottleneck depends on the game and performance target. The 4440 is not good at gaming but there are plenty of cases where it will work.
I suggest these
and then try to find a used i7 4770 with the leftover funds. it will make for a very good upgrade
