just noticed it today, fan goes from like 40% to 35% fan speed (not the exact number) you can hear and see if spin up, then go back to normal and then over and over again. it's only when i use MSI afterburner with the custom curve, but even the default curve does it. it only happens at <40% fan speed from what i can tell. Any idea how to fix it?
The fan speed doesn't actually go up in the program either
Specs:
CPU:
Intel® Core™ i7-9700K
RAM:
Corsair Vengeance RGB PRO DDR4 16GB
GPU:
Gigabyte GeForce RTX 2060 GAMING OC
Chassi:
Fractal Design Meshify C
SSD:
Corsair MP510 480gb NVMe & Samsung 850 EVO
250GB
HDD:
WD Desktop Blue 1TB
Motherboard:
Asus ROG Z390-F 1151
https://linustechtips.com/topic/1148964-graphics-card-changes-fan-speed/
GPU?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Normally if you run Afterburner and set a fan curve you should be fine.
Works for me...
Works for me...
Yeah it's been working for me too, it just now started doing it. Reinstalled the program but still the same thing, and my fan curve is pretty simple image.png.0dc6163ba1a570a883593ac136deb4b3.png
So basically your fans ramp up and down every few seconds? Have you checked for anything that would stop them from spinning freely (cables, etc.), or tried cleaning them?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
Why don't you set a fan speed to zero until 45~50c
Yeah exactly. Cleaned my entire pc a few days ago so no dust from what i can see nor any cables in the way. Happens on all three fans at only under 40% fan speed in afterburner.
I changed the fan curve a bit and seems to fine now? i'm very confused with what's happening lol
don't know rly, always used to have it like that, can't hear the fans at 30% and i just think that it's better to cool the gpu a little than nothing at all
Restarted the program now after "fixing it" and it's back, but i just reinstalled the software with the latest version as well, not sure what's causing it ?
When the GPU is at idle the temps are very low without the fan spinning.
I set mine to spin after 50c, right now it is at 32c no fan spinning.
Just re-seated and cleaned the graphics card, made sure there wasn't any cables but still the same issue
That's really weird. When did this start happening?
Changed some loud intake fans on my case a couple of days ago, might've not heard it before but from what i can tell it started today i think, but after googling around a bit it seems a lot of people are having the same issue with Gigabyte RTX cards
Then I'd suggest RMAing it. If you can change it for a different model though, that'd be ideal.
Yeah that's what i was thinking, support with the store i bought it from is closed until Monday. Bought the card a year ago now but they have good a good service so hopefully i can just switch it for a different model
