Doing massive upgrade and need help!
1 hour ago, Constantin said:Primary M.2: SSD ADATA XPG GAMMIX S5 1TB M.2 2280 PCIE GEN3X4
RAM: RAM CORSAIR CMW16GX4M2C3200C16 VENGEANCE RGB PRO BLACK 16GB (2X8GB) DDR4 3200MHZ DUAL KIT
Wouldn't really recommend that DRAM-less SSD.
I'll recommend Silicon Power A80, Sabrent Rocket, PNY XLR8 CS3030 instead.
16gb 3600mhz cl16 ram from gskill can be had for cheaper than the kit that you have selected.
1 hour ago, kingwolf1989 said:....
Here's what you can get....
Stock cooler does a fine job, but if your budget permits then you can get DRP4.
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor ($492.89 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler ($89.90 @ B&H)
Motherboard: Asus TUF GAMING X570-PLUS ATX AM4 Motherboard ($164.99 @ B&H)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 Memory ($149.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive ($124.99 @ Amazon)
Total: $1022.76
Generated by PCPartPicker 2020-01-24 01:58 EST-0500
