Posted January 21, 2020 Just got akracing max chair and having this issue putting the back onto the seat. On the right side of the seat there is this lever which you see in the pic, I accidently pressed it, and that metal bar in the pic will not stand up, so I can't place the back onto the seat to screw in. Any ideas of how to make the metal bar stand straight up again? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2020 Should be able to just pull the lever up and move the thing back Main stuff idk Laptop: Macbook Air M1 2020 Desktop/Gaming PC OS: Win 11 CPU: Ryzen 5 3600x MOBO: Asus ROG STRIX B450-F RAM: G.SKILL TridentZ RGB 16GB DDR4 3200 STORAGE: WD BLACK SN750 NVMe M.2 2280 1TB - Samsung 860 EVO 500GB SSD - WD Blue 1TB 7200RPM - Seagate Barracuda 1TB 7200RPM GPU: EVGA RTX 2070 Super XC PSU: Corsair TXM Gold 550W 80+ Other Stuff VR Headset: Valve Index Consoles: Nintendo Switch - Xbox Series X Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2020 Author 2 minutes ago, wookzi said: Should be able to just pull the lever up and move the thing back when i pull the lever i can move the metal bar but it goes right back down to that position, i need it to stand straight so i can screw the back in Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2020 35 minutes ago, Dylan lol said: when i pull the lever i can move the metal bar but it goes right back down to that position, i need it to stand straight so i can screw the back in Ther should in theory be a point where it locks. Be kinda weird if the chair folded in half every time you got out of it. Are you perhaps holding the lever open the entire time you are adjusting it? Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2020 Author 42 minutes ago, Bombastinator said: Ther should in theory be a point where it locks. Be kinda weird if the chair folded in half every time you got out of it. Are you perhaps holding the lever open the entire time you are adjusting it? yes im pulling the lever and moving the metal bar, and the metal bar goes back to the position in the pics Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 21, 2020 Pull the lever enough to get the thing to move then let go of it and slide it around till it clicks. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 22, 2020 ^^Think of this like your car chair (if you have a car) you pull the backrest lever and the thing will go forward and while holding it you have to put weight on it to move it back, then release the lever and your seat will stay and lock into place. Father of a 2 year old girl. #AutismAwareness From Halifax, NS, Canada Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
