Hello. I built my first pc and I’m starting to wish I didn’t. I got everything put together and plugged my Dell monitor in and I get the “display port cable not found”. I’ve tried all of the suggestions I’ve found and nothing has worked.
ive read ppl say “I just updated bios or graphics card driver, or windows.” How do you update anything when you have a blank screen? I’m getting frustrated and any help would be appreciated
https://linustechtips.com/topic/1147141-display-port-cable-not-detected/
Seems like a NO-POST situation (computer won't display anything).
check my signature for a troubleshooting guide and follow all instructions for no-post.
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
Are u sure the pc is booting (do u have a beeper) if you are sure the system is booted try out hdmi / DVI if your gpu still supports and are u sure your in the right output ? Did u plug in the dp cable at the gpu (if u have one) or in the Board above gpu be sure to be on the gpu not the board
1 minute ago, xhackforeverxdx said:
i Think it’s booting up. I don’t have the OS yet because the build that I copied had an optical drive and a case that didn’t have slots for it. So I gave windows on a disk.
When you remove the RTX 2060 and plug teh monitor to the integrated GPU, does it work then?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Actually just checked. Not getting a beep on startup
1 hour ago, Cheek Bust said:
Yeah. Set to display port you mean?
Yes. Also make sure you are plugged into the DisplayPort input port, not the DisplayPort output port.
There is only one port that it fits in
Is there a light I can check to see if cpu is on/working? I don’t hear beep or see lights
I don’t have a mem ok led lighting up
I think I made a serious mistake trying to build my own pc
Ok I just saw I have a yellow dram led. What does this mean?
Are you connected to the Mini DP port on the monitor? If so, you've set the monitor to Mini DP input?
3 hours ago, Cheek Bust said:
Maybe I should try this. What is the difference between mini and regular display port
Nothing, it's just a different shape connector.
