Need help upgrading my HP OMEN 15T (2017)
Solved by Jurrunio,
Just now, Raginryuu said:Thank you so much! Am I matching the NB Frequency or the DRAM Frequency?
DRAM frequency, seems like you have 2666MHz CL19 (DDR has double the data rate than actual frequency, also slightly behind because BCLK is not at 100MHz)
3
ShayOh ·
Posted in Troubleshooting2 -
Newbietobe5467 ·
Posted in Troubleshooting3 -
2
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
