Hello! I want to build a pc for gaming (esports titles mainly). I've got a budget maximum of 1100. I would greatly appreciate any help, response or even a better build! If you could build it in Germany that would be really helpful. I plan to use this for the next couple of years and maybe even upgrade it if possible.
This is what I have so far:
Thanks guys!
https://linustechtips.com/topic/1146715-advice-on-my-build/
This looks like a really well thought out build! Nice work!
I'd only say, keep in mind that Windows costs money (depending on the version you choose), and you also probably need a monitor, mouse and keyboard.
"Not breaking it or making it worse is key."
"Bad choices make good stories."
https://linustechtips.com/topic/1146715-advice-on-my-build/#findComment-13226955
If you replace the cooler, there is no difference between 3600 and 3600x.
The b450 board i picked is better and half the price of the x570 you picked.
Cheaper but as fast storage.
A freaking 2070 super.
Slightly cheaper case.
Cheaper and better PSU.
You can get windows for much cheaper if you search how
https://linustechtips.com/topic/1146715-advice-on-my-build/#findComment-13227017
Desktop benching:
https://linustechtips.com/topic/1146715-advice-on-my-build/#findComment-13227082
There you go mate....
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€193.90 @ Mindfactory)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  (€92.89 @ Mindfactory)
Memory: Patriot Viper 4 Blackout 16 GB (2 x 8 GB) DDR4-3600 Memory  (€88.80 @ Alza)
Storage: Silicon Power 1 TB M.2-2280 NVME Solid State Drive  (€137.84 @ Amazon Deutschland)
Video Card: Zotac GeForce RTX 2070 8 GB AMP Extreme Core Video Card  (€350.00 @ Amazon Deutschland)
Case: Cooler Master MasterBox NR600 (w/o ODD) ATX Mid Tower Case  (€72.81 @ Amazon Deutschland)
Power Supply: BitFenix Formula Gold 550 W 80+ Gold Certified ATX Power Supply  (€69.90 @ Amazon Deutschland)
Total: €1006.14
Generated by PCPartPicker 2020-01-19 03:11 CET+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1146715-advice-on-my-build/#findComment-13227205
