doubt it can play it very well.
but i can't find any proer benchmarks on it.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1146216-surface-pro-x/#findComment-13222888
Which configuration are you looking at / what would you consider to be a "good degree".
Most likely it won't perform where you want it, and there are other laptops that will offer greater performance at similar price-points.
I will complain about high prices in Norway given the oportunity.
Primary Desktop PC:
Hardware specifications:
CPU: i7-6700K @ 4.4GHz Motherboard: ASUS Z170 S CPU Cooler: NZXT Kraken x52 RAM: Crucial 16GB DDR4-2666 GPU: ASUS RX 5700XT ROG Strix SSD: Kingston Savage 240GB HDD: Seagate 3TB 7200RPM PSU: Corsair RMx 750W Case: NZXT H440
I/O:
Monitor: ASUS 27' 1440p 165Hz | AOC 24' 1080p 60hz Keyboard: Ducky ONE 2 SF (Cherry MX Brown) Mouse: Razer Viper Ultimate Headset: Sennheiser HD 6XX AMP/DAC: Drop O2 + SDAC DAC/AMP
(PC Part Picker Link)
Primary Laptop:
Dell XPS 15 9500:
CPU: i7-10750H RAM: 32GB DDR4-2933 GPU: GTX 1650 Ti SSD: 1TB NVME Display: 15.6' 1920x1200
https://linustechtips.com/topic/1146216-surface-pro-x/#findComment-13222890
