Hello guys, so i have my build down there, i already buyed some stuff, i just need to get the procesor and the motherboard from all that.
What do you say? its a nice build? :) I will only use it for streaming, video edditing and gaming, with only overclocking the CPU to max 4.2/4.3.
How do you think will perform? Should i change the motherboard and go for the Crosshair Hero VIII? I don't have in plan to overclock, only if i can with a easy way , to get 4.2/4.3, atleast.
And i buyed the msi rtx 2080 duke OC, cuz it was at a sale. xD
https://linustechtips.com/topic/1144413-ryzen9-build/
Could easily cut $500 out of the total cost and get the same performance
Desktop benching:
https://linustechtips.com/topic/1144413-ryzen9-build/#findComment-13208169
It's not terrible. Don't get the MSI motherboard, go with something like Gigabyte or AsRock.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1144413-ryzen9-build/#findComment-13208224
if ur gonna spend 3k on a build, get the 3950x, if it's not in stock, wait. it's a binned chip vs the 3900x is a trash bin.
For motherboard, if you are gonna use an AIO, get the z390 master for its vrm heatsink
The ram's one of the best but i highly recommend looking up timings/optimization, or get someone who's familiar with that kinda stuff to do it, makes a huge different.
I'd switch that hdd out for another sata or m2 ssd if the clicking sound is audible.
The monitor has 70% RGB and dci-p3 coverage with low contrast, consider a 500usd alterative like the 27QD or L850 if you haven't bought it yet, not something i'd pair with that pc.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1144413-ryzen9-build/#findComment-13208246
