Android Battery Health
Go to solution Solved by RadiatingLight,
If you take an android bug report, you can sift through the text files and it will have one field with the estimated actual capacity, so you can divide Actual capacity by 3520Mah to get the percent health.
from this post: https://www.reddit.com/r/GooglePixel/comments/b7qrgi/how_to_determine_pixel_charge_capacity_before_you/
In Dev options (settings/system/advanced/developer options) take a bug report (full report), upload the zip file here: https://bathist.ef.lc
Click on: Coulomb Charge (use only the blue reading at bottom, and divide it by the rated capacity which is posted below)
In my screenshot for my 1 yr old Pixel 2, it shows 2495mAh (rated capacity is 2700mAh for Pixel 2).
2495 ÷ 2700 = 92% remaining battery capacity (assuming my math skills are not faulty).
make sure battery is fully charged before doing this. no need to fully drain it before i think
So, we all know how iOS has a battery health status in it's settings to tell you how good the battery is. I'm running a Pixel 2 XL, Android 10. Is there any software that can get an accurate or at least close enough estimate to tell me how good my battery health is? I'm aware that I have to charge it up completely and let it die a couple of times.
https://linustechtips.com/topic/1144034-android-battery-health/
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Laptop:
Lenovo Yoga 7 Air: Ryzen 7840S, 32GiB DDR5
Desktop (Old but I never replaced it):
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 @2000Mhz
https://linustechtips.com/topic/1144034-android-battery-health/#findComment-13205369
