I hate to be that guy, but essentially your only option is to install Windows. Just a quick Google search and found that the game looks for some Windows verification files that it won't find any other way, even with something like WINE.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1142039-help/#findComment-13188538
Have you got a spare hdd around? if so, download the ISO for win 10 from MS, install onto the spare hdd and boot into windows solely to run the game.  Don't worry about activation.  it will still work without it.  When you don;t want to play remove the hdd and boot from your current drive back into Linux.
It's al;ot of work, but barring the possible cost of a small hdd it's free and gets the game running for you.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/1142039-help/#findComment-13188742
