After receiving a new ryzen 3700x for Christmas, I decided to place it into my computer. However, I forgot to update my bios from my old bios to the ryzen 3000 compatible version. So, I put the old cpu back in, and upon placing it back into the slot and reinstalling it, I tried to turn it on, but the power button won’t work, it won’t turn on, it appears to be fine, but nothing is helping.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/
You should check if the PSU is fine and try to start up the board by bridging the PWR pins on the board.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13186874
I should have clarified—I can start it,  it only when using the 3700x, the problem is, it won’t give a display, which I assume is the bios acting up
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13186927
So.. does your PC turn on or does it not?
In what way does it/does it not turn on? Lights, fan, post code/LED? etc.
Did it work before, does it work with the old CPU, does it work with the new CPU?
In your first post you said it won't turn on, now you are saying it does turn on..
You are connected to a dedicated GPU, right?
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13186932
Yes, sorry it turns on with the 3700x installed (when I press the power button). When I put the 2600x in, it appears to be working (motherboard is displaying boot) but when I press the power button, it won’t turn on. It worked fine before installing the new cpu, and I am using a dedicated gpu, specifically the Gtx 1080
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13186966
What do you mean with 'turns on' in the first and second sentence of your post?
Fan spin, LEDs, picture on display, etc.
- Double check if the PSU works: https://www.silverstonetek.com/downloads/QA/PSU/PSU-Paper Clip-EN.pdf
- Reset/clear the cmos/bios (see your motherboard manual how to do that).
Are you sure the BIOS update went right and supports both CPU types? No bent pins on either CPU, all cables properly plugged in, etc.?
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13186975
It turns on in the sense that LEDs are running, fans are on, but there isn’t anything going to the monitor
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187010
GPU fans too? I would reseat that and double check the power cables going to it. What motherboard do you have?
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187021
3 minutes ago, OddityZero said:
The GPU is on and should be seated properly. I’m currently using the Asus ROG Strix X470-i
What do these LEDs do?
 I would try booting with a single stick of RAM too. Have you cleared the CMOS/BIOS already, in case there was some incompatible memory profile set up?
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187090
I believe I have. How do you know when you have actually cleared CMOS
  Reveal hidden contents
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187116
Just follow these steps to clear the CMOS:
If you reset the CMOS, turn on the PC and see what those LEDs indicate.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187121
Just now, OddityZero said:
Okay I’ve done it. It appears that the normal standby led is on, but no others.
So when you turn it on, the Q LED just stays OFF?
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187146
This is the build while on, one more thing of note is that with the 3700x in there it turns ok but will only turn off when holding the power button for a full 5-10 seconds
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187179
16 minutes ago, OddityZero said:
I’m sorry, this is my first time doing this, could you point the specific one out to me?
Top right of your board.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187222
Nope. Nothing. None of them are on
That's weird, it doesn't detect CPU, GPU or RAM as an issue.. But also doesn't boot.
Unplug all your storage drives and mash DEL upon startup and see if that does anything. But before that I would just turn it on and leave it for a couple minutes, sometimes that helps too.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187287
In such a small case I'd imagine there is a higher chance something got knocked loose.  Did you check all cables, RAM, etc?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187322
Okay, I tried this, and the display shows nothing. It’s not getting any sort of signal, and the qleds are blank
I think they’re all there... I checked the gpu and the mobo atx power cable and nothing seems to be unplugged
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187331
I wonder if this might be relevant?  I haven't read through the instructions -- just stumbled across it going to your mobo manual.
https://www.asus.com/us/support/FAQ/1012219
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187345
The computer is on, (so it seems) but it won’t go to bios—It won’t even display anything to the screen
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187378
Try another display (like the TV). So the cable goes from the GPU to the TV.
https://linustechtips.com/topic/1141861-ryzen-bios-problem/#findComment-13187699
