Need advice on PC upgrades!
Solved by Scia,
The 2500k performs pretty much the same as it's IVY / Haswell counterparts so there's not much point in "upgrading".
If you want to upgrade your GPu go for the Single Card solution. Had 2 680s [~770 SLI] and had A LOT of hassle with it. Like ignoring DP connections once SLI was turned on, overclockability went down the drain and the likes. Go for a single 780 if you chose the Nvidia route.
