Hi dudes
amm
i live with... roommates so I install a Surveillance Camera and a NAS on a raspberry to host the files on the hallway to my room, buuut, I realize if they cut the energy that system is useless. So, I was wondering if exist something like usb ups (maybe something not to big like a normal ups), i try with a Sony powerbank, but it can’t do both things at the same time (it charges itself or provide charge to the camera)
you know something that can help me?
https://linustechtips.com/topic/1141124-usb-ups/
1 minute ago, emosun said:
Also , invest in a room safe.....  because that sounds like a serious living situation if you need surveillance camera or security reason inside of the home.
You aren’t providing help dude.
again... I need something lighter and smaller than a normal ups. the roomie situation is temporary, but I still want to have a something like I ask for.
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180860
There are powerbanks that allow doing both at the same time, but you'll need to lok at the specs for one that does.
But I guess if they can disconnect the input they can go disconnect the powerbank as well...
F@H
GPD Win 2
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180869
Hmmmm i will check that, my Sony one don’t do that shit
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180876
Hey, you actually understand the purpose of the forum, great, thanks.
No need to be rude mate, you said maybe something not to big, which means optional
If it is a requirement then state it is so.
Also UPS' dont just come as the big heavy units, you can get ones that are like power boards such as this which would mean you can use it for multiple devices which might be more what emosun was referring to: https://www.cyberpower.com/au/en/product/sku/bu650e
But probably what you're looking for is something like this https://www.aliexpress.com/item/32836106094.html
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180912
Dude, he said ma’am, I just replied with the same level. But I got it.
hmmm i like the first option, because I need at least two ports, one for the raspberry and other one to the camera. Thanks
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180928
You insist in calling people "dudes", but you were talking to a ma'am and she corrected you.
F@H
GPD Win 2
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13180953
13 minutes ago, ElihDW said:
I said dude to my grandma, hahaha, yes my bad
Just an update "dude" went out in the 80's something tells me you were not conceived yet ?
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13181007
On 1/2/2020 at 2:57 PM, ElihDW said:
Hi dudes
amm
UPS’s use very large and heavy batteries. I doubt they make them that small. Further more UPS’s are not really designed for long term power. Because they are very inefficient due to converting DC to AC and then your device converts it back to DC, even with a low load to no load eventually they will run out of power. Your might get an hour. With just my modem and router connected to my 850 watt rated UPS I got like 30 min tops.
https://linustechtips.com/topic/1141124-usb-ups/#findComment-13198512
