I really want to get into creating games but i dont know how
I dont know how to programm
i dont know how to draw
i dont know any programming languages
and i dont know how to put it all together in a game once i figure out how to do all this stuff
can any of you guys help me and tell me were to start, what to learn and how to do it in the end
thanks for your tips (oh and im also 15 so i have plenty of time to learn)
https://linustechtips.com/topic/114111-making-a-game-help/
lol. start with beginner programing, make a website or something.
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525055
I believe you can take an education in programming and game design. Look it up :)
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525059
Learn how to program and fuck around with the Game Studio software on Steam! :D I've made my first game with that to!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525066
You could start with something like this...
http://www.yoyogames.com/studio
But as others have suggested if you really want to make games well, design and coding is important...
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525069
I've started with Programming. I'm learning HTML right now, to make some web pages and stuff. Once I'm familiar with it, I'm jumping to C or C++. I'm also learning some editing and rendering and stuff. I'm also wanting to learn Graphic design, and creating music (FL 11). These all stuff helps in making games (Not flash :D).  I use Codecademy for learning Programming. Well, it ain't too easy for me as I hate math (The most Important in programming). Hope you love math, calculus.
 [spoiler=CORMAC]CPU:Intel celeron 1.6ghz RAM:Kingston 400mhz 1.99gb MOBO:MSI G31TM-P21 GPU:Will add one later on! CASE:local ROUTER D-Link 2750U, D-LINK 2730U MOUSE:HP,DELL,ViP KEYBOARD: v7 SPEAKERS:Creative 245  MONITOR:AOC E970Sw HEADSET: Sony MDRx05s UPS:conex ups avr 500va PSU:idk OD:Samsung super writemaster STORAGE:80 gb seagate+ Seagate 1TB OS:Windows xp sp3 themed to Windows 7 + Linux |Rest all pc in my house will be updated from time-time
COMING SOON
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525082
Learn to program (Start off with Python and then progress to something like C++/Java)
I would recommend this for Python: https://groklearning.com/
Excellent online courses.
After that, try your hand at Game Maker, so you know how a basic game is created.
The get into a SDK like Unity, CryEngine, or Unreal.
This should be spread out over the course of at least a year and a half.
If you have the school marks to do so, just don't bother with this and instead get a games programming degree at uni or something.
Ryzen 9 5950x | NH-D15 | ROG STRIX X570-F | G.Skill 32GB DDR4 | MSI Ventus RTX 3080 | WD Black SN850 1TB PCIe 4 | Samsung 850 EVO + 860 EVO 1TB | Corsair 5000D Airflow
Dell S3422DWG | Dell S2721DGF | Corsair K70 RGB Keyboard | Logitech G502 Lightspeed | ATH-R70x
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525092
Many people will hate on me for saying this but here's my suggestion, spend 1 week on Game Maker to get a better understanding of how games work, keep in mind that the games you'll be creating in this won't be your final released game unless you believe that it's ready to be released (which I won't recommend) . After this maybe spend around 1 month learning the basics of vb.net and keep in mind that this is to get a understanding of how to program and not how to make games, just to learn the basic principles of programming and stuff so create a simple app such as a calculator or something like that. Hopefully once you believe that you've got a good enough understanding of how to program then get into c# programming with xna. In this you'll start creating a more official game, I'd recommend buying this book for learning the basics and knowing how to use XNA in the right way otherwise just google how to do some stuff you want to include in the game.
Also just a side note I think that this post would fit under the Programming & Software Design section considering that it's quiet related to it.
https://linustechtips.com/topic/114111-making-a-game-help/#findComment-1525154
