Is there a way to control the volume though the receiver instead of the tv, the tv is a little hard getting to the IR eye. They have a way to change it to control the volume through the Blue ray or other connected device. I just think it is odd you can't pick the dish receiver
GIGA AORUSBYTE B550I PRO AX (AM4 AMD/B550/Mini-Itx/Dual M.2/SATA 6Gb/s/USB 3.2 Gen 1/WiFi 6/2.5 GbE LAN/PCIe4.0/Realtek ALC1220-Vb/DisplayPort 1.4/2xHDMI 2.0B/RGB Fusion 2.0/DDR4/Gaming Motherboard) ,AMD Ryzen 7 5800X 8-core, 16-Thread Unlocked 4.7 GHz, TEAMGROUP T-Force Vulcan Z DDR4 32GB (2 x 16GB) 3200MHz (PC4 25600) Ram, EVGA GeForce RTX 3060 Ti XC Gaming, 08G-P5-3663-KL, 8GB GDDR6, Metal Backplate, LHR
https://linustechtips.com/topic/1140048-dish-network-reciever-volume-control/
I have Dish and have never seen any kind of option like that. Pretty sure you can only change the volume through the AV receiver or the TV.
I control the volume through the AV receiver in one room and a TV in the other and never seem to have any issues with the IR. Do you have your seating arrangement at an odd angle in relation to the TV?
Perhaps your TV has some kind of IR dongle extender option? I'd look into that. Otherwise, maybe consider getting some kind of Harmony solution. Probably not what you want to do but if it solves the problem it is better than nothing.
  • 2 weeks later...
If you're having trouble getting a good "signal" (meaning: Line of sight) to the IR Receiver, you should just get an IR Repeater instead:
https://www.bestbuy.ca/en-ca/product/linkfor-ir-extender-infrared-remote-ir-repeater-extender-with-1-receiver-and-4-emitter-hidden-ir-system-for-amplifier-cable-bo/12343769
https://www.amazon.ca/IR-Repeater-System-Hidden-Control/dp/B0016PM63W
There are many options to choose from - basically you attach a small IR emitter directly overtop of the IR Receiver on your TV, then that emitter is connected to a different IR Receiver that you can place strategically in a better location.
A lot of them allow you to hook up multiple receivers, so you can control more than one device at once, but this is entirely optional.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
