Wireless network solution for one network with multiple APs and switches
On 12/30/2019 at 12:31 PM, Martin Jones said:I have some spare Asus routers which can be configured to "AP mode" automatically. Do you think having a main Asus router and hooking up additional 2 routers to it configured in AP mode would satisfy my needs? APs should be far enough (one would be in a garden house where the signal is almost dead. Would clients switch automatically and wouldn't be there any issue with multi-NAT environment and would all devices connected to different APs appear as on the same network? The main router would also have radio enabled.
Having the same SSIDs and being plugged into the same network in Access Point mode is all you ever need to achieve this on a basic level.
The only catch with that setup is devices tend not to automatically switch to the strongest signal so might need you to manually disconnect/reconnect. This is what mesh networking was designed to solve and what Ubiquiti APs also can do. (but then so can ASUS ones if they support AIMesh)
Honestly as you already have those routers, it wont hurt to try them first and see if you are happy with how it works. As great as Uniquiti APs are (and they really are), no point in spending money if your current equipment is good enough for your needs.
