It depends. What are you cooling?
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1523385
The absolute best AIO watercooler is the Swiftech H320/Cooler Master Glacer 320. Just make sure your case can support a 360mm (3x 120mm) radiator.
Also, what are you cooling?
I like the color scheme of Noctua fans. Deal with it. Forget about the bad memories of the past.
"wunder you really are as straight as a rainbow" - Lanoi "can I fisterino your nose" - WunderWuffle
Forget about the bad memories of the past, take the good ones along with you through the present, and look forwards to the good things that will come in the future.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1523505
I just wanted to know what would be considered the best choice for all in one liquid cooling?
I have chosen the Thermaltake 3.0 is this a good choice or no?
The thermaltake 2.0 was noisy and the pump had a low pressure problem so i would stay away from the 3.0. If you really want a closed loop water cooler i would suggest the NZXT Kraken and swiftech h220.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1523636
still got Extreme 2.0 with 12,000hrs since Aug/2012 with no issues and been ragged on a lot.
the fans are not the best (replaced with Helix PWM) and is a solid performer. as to the 3.0
hadn't tried it (prolly won't) similar to the thin 240 AIO kits.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1524106
I installed the 2.0 in a PC in 2012 but the pump was loud even after 4 drains and fills. I don't know if the pump had an air bubble that could not be moved or not but i did shake it while is was leak testing but it was futile. After reading some reviews i found other people had this problem as well so i thought it was jut a fault of the pump. I personally have the XSPC X20 750v4 and i can say it has been running over a year 24/7 and i have had no problem and it is quieter than the XSPC fans and the 200mm fans in my P630 at full speed but only when you fill the water 3/4 to full of the reservoir.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1524155
must be talking about a different thermaltake extreme 2.0
CLW0217_5623baa9c64f46f6a01a3f8d1572bf22
sealed, non-service AIO
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1524213
My case can only support a 240mm (2x120mm) radiator. It's for cooling a i7 4770k.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1525914
I have thought about this cooler as their doesn't seem to be much information about the 3.0 online. As for the 2.0 it doesn't say its compatible with lga1150 motherboards.
https://linustechtips.com/topic/113991-liquid-cooling/#findComment-1526162
