Hello guys I'm a fairly newer PC builder. I just built my pc a few months ago and i recently installed a three fan liquid cooler on it. I'm looking for recommendations on my airflow and would like to see what you think. I have inserted a picture of my current air flow and an air flow set up that I was thinking about doing. Right now, my front three fans are the intake and my liquid cooler at the top is the exhaust. I worry that not enough air is reaching the GPU which is why I am thinking about keeping the outer two exhaust fans on my liquid cooler radiator as exhaust, and changing the middle one to an intake. What do you guys think about this? Is my current set-up fine, or is my proposed one better? Do you guys have any other suggestions? Thanks!
https://linustechtips.com/topic/1139832-air-flow-recommendations/
Those front fans should deliver an adequate amount of air to the gpu you shouldn't need to flip the fan on the AIO. All in all your case flow in its current config seems pretty balanced if not slightly positive pressure due to rad resistance.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
I honestly prefer doing all intakes except for the Back case fan by the IO panel, that is my exhaust. Works well for my systems overall.
I can't fit any of my fans in the back due to the AIO pump lines. How many fans do you have as intake compared to your one exhaust in these systems? Do you think three fans as exhaust and three fans as intake is too much intake?
There is never too much intake :) I have 3 top intakes (3 120mm fans) 2 front intakes (2 140) would be a third but i have an older case, and 1 exhaust. All Computer builds that i do for people i do this because it generally just works the best.
Am I looking at this picture right? The fans on the front of the case appears to be mounted as exhaust unless those are some special design where the frame on blade side is on the opposite side.
The top fan with the radiator should be all exhausting. And then I would put a exhaust fan on the back to help push out the air so it won't suck in so much dust.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
All of the front fans are intake. I feel like having four exhaust fans would cause too much negative pressure.
I would normally suggest using front intake and top exhaust.
I do believe that you could be confused about which way the air flows through our fans.
You currently have your fans setup to top intake and front exhaust.
The air always flows from the front side through the fans towards the back.
I would not recommend having 1 of your top fans as intake and the other 2 as exhaust.
If you set your front fans as intake it will supply ample amount of air to your GPU.
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: Be Quiet! 500DX   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
8 hours ago, Paintmaker9000 said:
No, the rad is exhausting and the front fans are intake.
Actually, @alyen and @Jeppes are correct, you have both top and front fans wrong way. See the pic:
Fans exhaust from bracket-side and intake from blade side. The 3 in front and 3 out top is fine, just flip the fans around.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
