WiFi Cards for under $50?
QuantumBit
My current WiFi card gets ~14 Mb/s down, when it's supposed to be around 250 Mb/s. I've tried powerline and it went better (but still no where near enough), and I can't run ethernet.
What are some good pci-e cards for under $50, preferably cheaper (it doesn't have to reach 250 Mb/s, it could be around 80-120)
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
What router do you have?
How far away are you from the router?
I assume your router supports AC and you're not too far away but want to make sure before I recommend anything :)
Current Network Layout:
Current Build Log/PC:
Prior Build Log/PC:
Just a default one that comes with the WiFi
Around 10 feet but theres a door in between it
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
Personally I'd go for something like https://amzn.to/2StYMjv
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Thank you!
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
