Cat 6a copper cable on a Gigabit Unmanaged Switch
Solved by dalekphalm,
1 minute ago, Hunyo18 said:Will it still transfer 10gb even though the switch supports 1gigabit and not a 10gigabit? Thanks for the info. Sorry for the late reply.
No. You will always be limited by the slowest component.
If on one side you have a 10GigE NIC, a Cat6a cable, and then a 1GigE switch, the entire link will run at gigabit. Same goes if it's 1GigE on both sides. The cable can simply handle faster IF your nic + switch support it.
