Hello Guys
i have a problem. I am currently building on my new pc and my graphics card neither shows up in the bios nor in the device manager in windows. I have tried both pcie x 16 slots and changed the power supply cable and the slot on the psu but it won‘t change anything.
I‘m desperate for help.
thanks
UselessSuperhero
https://linustechtips.com/topic/1137462-rtx-2080-ti-problem-pls-help/
Are you using any video adapter cables per chance?
Primary PC:
PSU tier list
How many watts do I need?
Your motherboard is giving a warning message that there's no CPU fan plugged in. Make sure the fan is plugged in to the CPU_fan header so it doesn't trip the warning.
You should also enable xmp to run your memory at its full speed. It's showing 2133mhz.
Have you installed the latest drivers for your video card? You can download them directly from the NVIDIA website.
Do you have the display cable going to the monitor plugged in to the back of the motherboard or to the graphics card? Do you get a signal when it's plugged in to the graphics card?
