which pci slot for esata card
Walt
Hi!
I'm planning on installing an eSata card I found into my pc. I will use it for connecting hard drives and such. My only question is in which slot I need to put it and does it have impact on any other parts (graphics card or m.2 ssd).
My motherboard is a Z270 msi pro carbon and has 3 x16 pci lanes and 3 x1 slots.
Thanks!
My own build: RΛZΞR theme
CPU: Intel Core i5 7600K // CPU cooler: Cryorig H7 // Motherboard: MSI Z270 gaming pro carbon //
Video Card: MSI Armor gtx 1070 OC 8GB // RAM: Corsair Vengeance 16GB 3200MHz //
SSD: Samsung EVO 960 500GB // HDD: 2x WD yellow edition 2TB //
Case: NZXT H440 RAZER edition // Power Supply: Corsair RM550x //
Operating Software: Windows 10 pro 64-bit
Just plug it into what it requires. If it needs a full size slot, use that. If it's an x1 size connector, use that.
A 1070 can't saturate x8 3.0, but if you want to keep x16 active on the top slot anyway AND this eSATA card needs a full size slot, use the bottom most one and that will trigger x16 x0 x8 on your specific board.
MacBook Pro 16 i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME
iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20
Thanks! The card is really small and (I think) needs a x1 slot. Is there any wat I can see whatever lane uses how much x16/x8/x4 etc. for when I plug it in?
I just grabbed it from the product page I looked at earlier:
Quote
3 x PCIe 3.0 x16 slots (support x16/x0/x4, x8/x8/x4 modes)
So just take the order they're written in and apply it top to bottom for your 3 slots. The x1 slots shouldn't have any effect on the big ones.
