Yo guys, so my gpu has a max Core clock of 775 MHz and and Memory Clock of like 1000 MHz and for some reason, The core clock is always at 300-400 MHz, and the memory clock is at 150-300 MHz (Even when gaming), I have no bottleneck, and the GPU or CPU is not overheating, it stays at 50 degrees, how do i Fix this, I have so many fps drops and I lag so much.
My custom loop 5000$ PC:
 CPU: Intel i7 9900k Motherboard: Asus Prime Z390-A RAM: 32GB (x4 8GB Modules) Corsair Dominator VideoCard: Asus Nvidia 2080ti HDD/SSD: 1TB M2 Samsung EVO 970 Case: LianLi O11 Dynamic (White) Radiator: x1 Corsair Hydro X Series XR5 360 Fans: x6 Corsair LL120 RGB Tubing: Thermaltake PETG ID: 13mm OD: 16mm Fittings: Bitspower Throughout Waterblocks: CPU: EK-Velocity RGB (Nickel+Plexi) VideoCard: EK-Vector RTX 2080ti w/ Nickel Backplate (Nickel+Plexi) Reservoir: Bitspower Touchaqua Sedna Front Plate Options: Corsair Commander Pro, Corsair RGB Controller, Custom Sleeved Cables for CPU, ATX and PCI-E
https://linustechtips.com/topic/1137159-gpu-not-using-its-max-potential/
SPECS!!!!
Please.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
And what 'GPU' would this be?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
what hardware are you actually using?
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
18 minutes ago, HanZie82 said:
SPECS!!!!
Please.
intel i7 4500u
AMD radeon HD 8870M
16 GB ram
amd radeon hd 8870m
And what do you use to show the info?
If you need to ALT+TAB to see the info that might be why.
Also make sure your GPU drivers are up to date.
Their up to date and I use MSI Afterburner
And i tried playing it windowed with the msi afterburner running next to it, and still same thing
