Great Wireless Headsets?
Hello,
I am finally considering to buy a wireless headset for gaming but it seems they are all sh¡t.
I'm used to a DT770 Pro 250Ohm from 2003 powered of a Samson Amp and an AKG P120 Mic. this setup is still very hard to match.
I had the Steelseries Artic 3 Bluetooth at home, the sound was acceptable after a few hours of equilizer tweaking until I found out that bluetooth doesn't support quality bidirectional audio, so I sent it back.
So I am looking for a casual wireless gaming headset ideally compatible with PC, PS4, and Smart TV somehow and the sound shouldn't be complete garbage I know there won't be a wireless headset that compares to my DT770 but if it's as good as the Arctic 3 I can live with that but the Mic should work on PC and PS4 with normal quality.
The weak point of the story is I am looking for something at a price point about 120€
Hope someone can help :)
https://linustechtips.com/topic/1137018-great-wireless-headsets/
I'm realy no fan of the software surround stuff I know it can give you advantages in competetive play but it's everything but clear sound, also I think this won't work on samsung TV isn't there a headset that works with wireless usb adapter and bluetooth?
You can just turn the surround off then and play in stereo.
And I don't know of any headset with a dongle and bluetooth.
