Welp, Ma CPU Was Dropped
Solved by Lurick,
You dropped it inside the clamshell that houses the CPU?
It's fine. Unless you stomped on it and bent the pins, you're good.
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting6 -
Nebcs ·
1
FancyPants101 ·
