Any benefit to displaying 2k or 4k resolution on a 1080 monitor
steelo
Hi everyone,
I read a few articles online about how through down sampling (I believe that's what it was called) you can display 2k or 4k resolution on a 1080 monitor (kind of) They claim that it will produce a 'richer' sharper image, especially during gaming. I'm just curious if this is in fact true and worth the cost in performance. I understand that trying to display a higher resolution than the monitor can support will probably make the display look worse and that a 1080 monitor isn't magically going to gain more pixels. However, will it eliminate some of the pixelation in games?
If I have a GPU that can handle down sampling from 2k or 4k to 1080p, is there any benefit?
Well I honestly don't have any technological knowledge about this, but I do know that when I view a youtube video of a game uploaded at 4k on my 1080p monitor is has a much sharper image quality than watching a youtube video of the same game uploaded at 1080p so there might be some truth behind down sampling to get a better quality picture.
If I were you, I would honestly just try it out.
Personally I don't like non round multiplications (e.g. 1440p on a 1080p is a 1.33 times multiplier if memory serves me right, whereas 2160p is 2x in both width and height), but your mileage may vary.
The name Nvidia gives this technology is DSR (Dynamic Super Resolution). When you try to display a 2160p image on 1080p, it's kind of a similar effect as using Anti-aliasing. You are taking a large picture and pushing it into a smaller image. That reduces certain artifacts, like 'jaggies' in the same way Anti-aliasing removes them. AA uses a different way of achieving this though
DSR works by rendering the image at a higher resolution (be that 2K or 4K), then samples the improved image back to 1080p. It's anti-aliasing on steroids. It's not going to magically give you 4K quality, but it will dramatically smooth out the image you see at the expense of framerate. If you've got, for example, an RTX 2070 and a 1080p 60Hz monitor, DSR is totally worth it because that 2070 is way overpowered for your display.
Aerocool DS are the best fans you've never tried.
Thanks, I will be getting a RX5700 in the next few days...I believe AMD refers to it as virtual super resolution? Do you believe this GPU is powerful enough to downsample, say 2k to 1080 (to give it a round number) and maintain 60 fps?
I could try it on my current RX570 just to see if the images look clearer but the frame rates might be ugly...LOL
Yep, Virtual Super Resolution. Can be enabled in the Radeon Settings panel. I kinda glanced over part of your post where you mentioned '1080' and my mind immediately thought you had a GTX 1080 :P
The 5700 non-XT is powerful enough for 60fps gaming at 1440p. 4K might be difficult at Ultra, but it depends on the game.
Just so we're on the same page.. When you say 2K, do you mean 2560x1440? Because that would not be a round number. 2560 / 1920 = 1.33 repeating. 1440 / 1080 = same.
With a round number I meant 2 times the width, 2 times the height. So 3840x2160 ('4K'/'UHD').
As I said though, your mileage may vary, but personally I always prefer round numbers when scaling up or down.
Just so I understand...1080=1920x1080, 2k=2560x1440, 4k=3840x2160?
I've always assumed 2k is twice the resolution of 1080, 4k being 4x the resolution but I haven't put a lot of thought into in in the past...LOL
So I'm better off trying to downsample from 4k to 1080 rather than 2k to 1080?
The K-terms are super confusing.. I blame 4K!
The K-terms are - depending on who you ask - unofficial terms to refer to different classes of monitor resolution. It being the (rough) amount of of horizontal pixels.
When people say '4K', they usually mean 3840x2160, some people refer to 4096x2160. Those are both kind of roughly 4000 pixels wide.
2K is a term I personally kinda of dislike, because to be honest.. 1920x1080 is closer to 2000, than 2560x1440! But I have accepted that most people when they say 2K mean 2560x1440..
But why I blame 4K: 3840x2160 is both twice as wide and twice as tall as 1920x1080. So some people think "Oh, so 4K means 4 times the pixels of 1920x1080!, that mean 2K = 2 times the pixels!"
But why I blame 4K: 3840x2160 is both twice as wide and twice as tall as 1920x1080. So some people think "Oh, so 4K means 4 times the pixels of 1920x1080!"..
Darn it, you caught my post before I could edit it so I don't appear to be an idiot...LOL. So, really 2k is 1.33 times 1080 resolution and 4k is 1.33 times 2k resolution?
Am I better off trying to downsample from 4k to 1080 rather than 2k to 1080 (to give it an even multiplier)?
I edited the quote in my post, the past can stay in the past :ph34r:
Personally I don't like trying to display 2560x1440. Just didn't look that good. I played certain games like that and did not like how it looked. You can certainly try it out yourself though.
Oh and I forgot to finish my previous post it seems..
Why I blame 4K for the confusion: people think "3840x2160 = 4 times the pixels, so what people refer to as '2K' (2560x1440) surely means 2 times the pixels!"
That's EXACTLY what I (the average consumer idiot) believed! I'm sure this was a ploy by the big tech companies in their naming conventions...LOL
Anyways, thanks for clarifying this for me!
59 minutes ago, steelo said:
Hi everyone,
It's called DSR, and I recommend keeping it off on the desktop, as it looks horrendous, or set to 4x in games, because it does make it look sharper. I only recommend using it if your hardware can run 2160p at whatever framerate your monitor is (60hz, 144hz, 240hz), as it isn't worth the hit to performance if you drop below 140fps in my opinion.
Hot Mist (Main PC)
Case: NZXT H700 Black (Signed by LTT) | CPU: AMD Ryzen 9 3950X | Cooler: EKWB AIO CPU Cooler 360mm, with 3x Noctua NF-F12 Fans | Motherboard: Gigabyte X570 Aorus Master Gaming Motherboard | RAM: 2x G.Skill Trident Z Neo 32GB (2x16GB) 3600MHz CL16 DDR4 | SSD: Corsair MP600 2TB, Samsung 970 EVO 2TB, Samsung 970 EVO 1TB | HDD: Seagate Barracuda 4TB | GPU: ASUS GeForce RTX 3090 TUF Gaming 24GB | PSU: Corsair AX1200i Platinum 1200W, CableMod PRO AXi Cable Kit Black/White | Fans: Noctua NF-A14 Fan, 3x Noctua NF-F12 Chromax Fans | Monitors: ASUS ROG PG27UQ, 2x ASUS ROG PG27AQ | Peripherals: Razer Huntsman Elite (Red Switches), Razer Mamba Wireless, Elgato Stream Deck Mini | Audio: Sony MDR-M1ST, Audio Technica AT2020, Audio Technica BP40, Rode PSA1 Boom Arm, Topping D70 (Bluetooth) DAC, Drop x THX AAA 789 Amp, Rode RODECaster Pro Audio Interface, Audio Technica ATH HPH300 | PCIe: Elgato HD60 Pro | Webcams: Logitech C922, Logitech BRIO 4K | Other:  iPad 7th Gen 32GB
Self Loathing (Portable Gear)
Phone: Samsung Galaxy S20+ (Exynos 990) | Watch: Samsung Galaxy Watch 46mm (w/ Pink Strap) | Audio: Samsung Galaxy Buds+ (Black), FiiO BTR5 Bluetooth AMP/DAC | Laptop: Razer Blade 15" (10875H, 2070S, 300hz), Razer Mamba Elite | Other: Spektrum Prospek-50 Arctic (Prescription)
The Preciouses (IEM Box)
Case: BLOODYRIPPA Luxury Watch Box 12 Grids | IEMs: Audio Technica ATH-CKR100iS, TINHiFi P1, FiiO FH7, Audio Technica ATH-E70, Shouer TapePioneer SE-CH9T (BanG Dream! Girls Band Party! Roselia Collaboration Model), Moondrop S8, Moondrop Starfield, Kinera Nanna, IKKO OH7, IKKO OH10
So Head? (Headphone Collection)
Hooks: 2x Razer Headset Stand, 1x Audio Technica ATH HPH300 | Headphones: Kingston Hyper X Cloud II, Audio Technica ATH-M50X, Sony MDR-CD900STBeyerdynamic TYGR 300 R, Sennheiser HD600Sennheiser HD6xx, Cooler Master MH751
Crossed out means they are too be purchased, on the way for delivery, or broken and planning to repair.
Nuf Repus (Arcade PC) (upcoming)
Case: Corsair Carbide Series 275Q | CPU: AMD Ryzen 3 3100 | Motherboard: Gigabyte B450M DS3H Wi-Fi Motherboard | RAM: Corsair Vengeance LPX 16GB (2x8GB) 3200MHz CL16 DDR4 | SSD: Kingston A400 240GB | GPU: Galax GeForce GTX 1650 EX OC 4GB | PSU: Corsair RM550x Gold 550W | Fans: Noctua NF-A14 Fan, 3x Noctua NF-F12 Fans | Monitor: Viewsonic VX3276-2K | Peripherals: Razer Blackwidow Chroma V2 (Yellow Switches), Razer Deathadder Elite, 2x Dance mat EX PRO + The Handbar | Audio: 2x Klipsch R-610F Floorstanding Home Speaker, Behringer A800 AMP | Webcam:  Logitech C922
Sound Euphonium (Music Setup) (upcoming)
Laptop: Razer Blade 15" (10875H, 2070S, 300hz) | Monitors: LG 24BL650C-B, 5x iPad 7th Gen 32GBInstruments: ESP Electric Guitar Random Star (Red), Yamaha APX600, ESP Electric Bass Viper (Pink), Roland RD-88, Pearl Export Double Bass 8-Piece Drum Set (Black Cherry Glitter), Neumann TLM 103Audio: 5x Sony MDR-CD900ST, speakers5x PreSonus Audiobox USB 96 Audio Interface, Golden Age Project PRE-73 MKIII | Webcams: 5x Logitech C922, 5x Logitech BRIO 4K
Thanks, I'm hoping my RX5700 will have the horsepower to maintain 60 fps (my monitor is only 60hz) downscaling from 4k to 1080. Now, that brings up another question...is it more beneficial to display higher graphic detail settings in games or downscaling from 4k-1080?
