Wifi not connecting, but was working?
cadvice
So all of a sudden I can't connect to my wifi, Its been working fine for around 12 months.
I left my PC running doing some rendering for around 18 hours then when I came back I can't use my wifi ?
So I tried my tablet to the router connecting fine,
So then I set my tablet to hotspot mode PC connects to my tablet fine.
But try to connect through my router nothing says connecting than flashes up disconnect. Says cannot connect to this network ?
Any ideas ?
Thanks ian
Ok so I think I've found what I'm looking for, found a post with the same problem identical infact.
Now it says he updated the Broadcom drivers no links or anything else.
Now where's the best place to download from and is this a windows driver or some sort of hardware driver ?
What wireless NIC do you have?
Asus ac68 it's ok I'm abandoning this. It's a Broadcom 34xx I've tried every driver I could find best I found lasted 10 mins before reverting to the same problem.
It's apparently a common problem when using AMD cpus with them they've known of the issue since 2014 and done nothing about it.
Thanks anyway.
