Where to buy outside ethernet cables from?
Solved by mariushm,
Go to distributors or networking equipment, cable, telecommunication related stuff.
If nothing comes to mind, look at distributors of electronic components.
You have Farnell and RS Components in UK
example: https://uk.farnell.com/c/cable-wire-cable-assemblies/networking-cable
You can use the filters on the side to pick various insulation material, cat ratings etc but chances are unless you buy a 300m spool, it's gonna be expensive. I've pre-selected cat5e and better.
Example of outdoor cable with extra material inside the jacket for protection and all that :
PP001511 PRO POWER, Networking Cable, Outdoor LAN, Water Resistant | Farnell
PP001510 PRO POWER, Networking Cable, Outdoor LAN, Water Resistant | Farnell
