Planing for a biuld....
Go to solution Solved by WoodenMarker,
Gaming. BF4/Crysis 3 and other demanding games while recording.
Better: http://pcpartpicker.com/p/2QrPq
Hey guys!
I have gotten a job recently and I am saving up for my first PC. This is what I am looking at: http://pcpartpicker.com/p/2Qqrq
I will be upgrading to a R9 290/290x, or a 780/ti. Mu budget is really no higher then what is there. Will this work or should I change something?
(I haven't logged in in years, I have to update this)
My PC Spec:
CPU: Intel i7-8700k @ 3.7GHz, Motherboard: , Memory: 16gb , Storage: , Storage: Crucial BX100 250GB, Storage: Seagate Barracuda 3TB 3.5" 7200RPM, Video Card: EVGA GeForce GTX 970 SC(x2), Case: Corsair C70 Green, Power Supply: EVGA SuperNOVA NEX750G GOLD, Operating System: Windows 8.1, CPU Cooler: CORSAIR Hydro Series H100, Optical Drive: LG Internal Super Multi Drive
https://linustechtips.com/topic/113573-planing-for-a-biuld/
Hey guys!
8320, air cooler, m5A99FX EVO/GA-UD3, Seagate 7200 RPM 3TB drive, less RAM, better GPU
re-evaluate build before buying, planning a build ahead of time is bad.
and do you really need a blu ray drive?
Error: 410
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517525
Switch to Windows 8.1
Also, why do you need 16gb of RAM? Seems kind of excessive
Also, you can probably get a better value on that CPU cooler
Meant to do that... :P
The 16 gb is more for video rendering and such.
Bluy-ray, yes. It would be the only one in my house. Maybe... IDK, might take it out.
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517528
8320, air cooler, A99FX EVO/UD3, Seagate 7200 RPM 3TB drive, less RAM, better GPU
He said that he will be getting a better GPU in the future
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517530
Hey guys!
CPU:  AMD FX-8350 4.0GHz 8-Core Processor  ($189.99 @ Amazon)
CPU Cooler:  Corsair H100i 77.0 CFM Liquid CPU Cooler  ($89.99 @ NCIX US)
Motherboard:  Asus SABERTOOTH 990FX R2.0 ATX AM3+ Motherboard  ($176.99 @ SuperBiiz)
Memory:  Kingston Black 8GB (2 x 4GB) DDR3-1600 Memory  ($76.47 @ Amazon)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($89.99 @ Amazon)
Video Card:  Asus Radeon R9 280X 3GB Video Card  ($328.99 @ Staples)
Optical Drive:  Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer  ($58.99 @ Amazon)
Operating System:  Microsoft Windows 8 (OEM) (64-bit)  ($97.98 @ OutletPC)
Total: $1360.30
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-09 21:02 EST-0500)
Specs
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517532
What's the system being used for?
Why the Red hdd? ...is the bluray drive really necessary?
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517538
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ Newegg)
CPU Cooler:  Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler  ($79.99 @ Newegg)
Motherboard:  Asus M5A97 R2.0 ATX AM3+ Motherboard  ($79.99 @ Amazon)
Memory:  Corsair XMS 8GB (1 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Video Card:  EVGA GeForce GTX 780 3GB Video Card  ($489.99 @ NCIX US)
Total: $1252.56
(Generated by PCPartPicker 2014-02-09 21:04 EST-0500)
Welcome to the Gun Show
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517544
Total: $1360.30
^ this, but i would change the 280x to a 770 b/c of mining driving the price up
PC Specs
Intel i5 4670k 4.2ghz @1.20v | Cooler Master 212 Plus | Asus z87-A | Fractal Design Define R4 |Hitachi 1TB 7200rpm HDD | 2x Samsung 840 EVO | Seasonic 520w m12II | Crucial Ballistix Sport 8gb DDR3 1600mhz | PowerColor 7870 GHz edition | Razer Blackwidow Ultimate 2013 | NZXT Hue RGB Controller
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517558
Red for price. Bluy ray, maybe not because I might be getting a PS4 which has bluyray. If not, this would  be the only blue ray I would have in the house.
A little more info: It will be used for gaming, mostly BF4 and Crysis 3. I want to be running 3 1080p monitors also.
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517566
i selected amd because of his first post wasnt sure if he was a all amd guy
Specs
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517569
The red isn't exactly cheap. The barracuda is quite cheaper and faster. http://pcpartpicker.com/part/seagate-internal-hard-drive-st3000dm001
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517572
Nah. AMD is just cheaper. :D On GPU, I really don't care. Just want Performance to price.
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517579
well then just switch out the 280x for a 770 or something and the 8350 will be fine tbh id like 8 cores and intel dosent offer that right now D:
Specs
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517590
I changed it a bit. How about this? http://pcpartpicker.com/p/2QrBq
PCPartPicker part list / Price breakdown by merchant / Benchmarks
Motherboard:  MSI 990FXA-GD80V2 ATX AM3+ Motherboard  ($171.49 @ Newegg)
Memory:  G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2133 Memory  ($74.99 @ Newegg)
Storage:  A-Data Premier Pro SP600 128GB 2.5" Solid State Disk  ($77.27 @ TigerDirect)
Storage:  Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($100.00 @ NCIX US)
Video Card:  Gigabyte GeForce GTX 770 4GB Video Card  ($388.99 @ SuperBiiz)
Case:  Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case  ($89.99 @ Newegg)
Power Supply:  Corsair CSM 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Operating System:  Microsoft Windows 8.1 - 64-bit - OEM (64-bit)  ($99.98 @ Best Buy)
Total: $1352.68
(Generated by PCPartPicker 2014-02-09 21:22 EST-0500)
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517616
What kind of performance are we talking about?
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517618
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517622
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517642
Motherboard:  Asus M5A99FX PRO R2.0 ATX AM3+ Motherboard  ($119.99 @ Newegg)
Memory:  Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($139.99 @ Microcenter)
Storage:  Crucial M500 120GB 2.5" Solid State Disk  ($72.99 @ NCIX US)
Power Supply:  Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Microcenter)
Other: EVGA 780 ACX B Stock ($439.00)
Total: $1413.90
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517668
Ok. Now, does the FX 8320 come w/ a heat sink or do you have to buy a separate one? If it comes with one, I might not get one right off the bat and wait a week. Learn how to overclock or something in that week.
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517671
Yes, it comes with the stock cooler.
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517673
Ok. Then I will probably hold off. Get a custom water loop or something. :D
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1517699
Could I change the ram to be a red color? Like the G.SKILL Ripjaws X Series 8GB F3-12800CL9D-8GBXL?
My PC Spec:
https://linustechtips.com/topic/113573-planing-for-a-biuld/#findComment-1529336
