Looks like a bit too much imo
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138647
Well, it shouldn't have gone anywhere else but the top of the GPU die, yours get on the sides. Luckily it's not a conductor of electricity.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138649
1 minute ago, LIGTHIN said:
That's the old paste
Be careful when removing it, not to damage the tiny capacitors.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138654
Cos you put quite lot on the die, all of this will spread out and will make even more mess around die
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138655
Just now, emosun said:
Yeah i'm not sure why the comments are so kind , but thats a mess
Because we’re nice guys ?
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138691
Should have just put a pea size in the middle.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138694
i'm confused as to what you meant with
is that the paste that's on the board itself?
or is it the paste thats on the entire cpu.
because if you're going to apply new thermal compound you definitly want to remove that layer first.
Anything i've written between the * and * is not meant to be taken seriously.
keep in mind that helping with problems is hard if you aren't specific and detailed.
i'm also not a professional, (yet) so make sure to personally verify important information as i could be wrong.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138697
Did my best to remove it again is this better
Much better ? now remember not too much tp ?
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138703
It was just fine the first time you applied it (not the best but just fine)
You guys making those comments did you ever remove the GPU heatsink? did you notice how messy is the paste application?
OP's application was a masterpiece compare to industrial apply!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138714
Way cleaner. Now, apply the new paste and that's it. Cover the whole die (since it's not a heatspreader).
PS: Don't forget to clean the heatsink and remove the old paste from there.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138724
On my Asus strix thermal paste was horrible when I took it apart first time ? now I’m changing it at least once every 6 months.
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138727
Good?
Not good ... perfect ?
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138743
4 minutes ago, LIGTHIN said:
Good?
Extremely. Well done.
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138749
Not to destroy the thread, but from my own testing with kryonaut, a small drop in the middle will yield better results as the past is spreading in a more even manner.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138751
I’ve tried both of the methods and didn’t seen any difference between them
                                          WHIRO
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138754
Alright :) The good thing about spreading is that you won't get any excess paste on the sides.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1135677-thermal-paste/#findComment-13138758
