Hi all, I've been planing to build my first PC for a couple of weeks now. I've done some research on the components, but I'm pretty new to PC building, specs and all of that, so I'm not sure if the components I've chosen will perform as good as possible.
This build will be mostly used for gaming/streaming (hopefully Halo Infinite and other FPSs), some 3D modeling (ZBrush) and illustration (Photoshop) and would like to have room for some overclocking.
So my questions are:
  • Which of these components would you change?
  • Is the power supply an overkill?
  • Do you have any recommendations, do's and don'ts?
Thanks.
PCPartPicker Part List
CPU: Intel Core i9-9900K 3.6 GHz 8-Core Processor  ($489.99 @ B&H)
CPU Cooler: NZXT Kraken X62 Rev 2 98.17 CFM Liquid CPU Cooler  ($136.36 @ Amazon)
Motherboard: Gigabyte Z390 AORUS MASTER ATX LGA1151 Motherboard  ($249.99 @ Newegg)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-2400 Memory  ($129.99 @ Amazon)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive  ($169.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Amazon)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB VENTUS OC Video Card  ($699.99 @ B&H)
Case: NZXT H510i ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: EVGA 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($71.98 @ Newegg)
Monitor: Dell S2417DG 23.8" 2560x1440 165 Hz Monitor  ($329.99 @ Dell)
Total: $2418.26
Generated by PCPartPicker 2019-12-17 14:49 EST-0500
https://linustechtips.com/topic/1135522-1st-build-noob-needs-help/
6 minutes ago, Windoors said:
Why not go AMD 3900x or 3950x
Amd cpu are better value for multitasking right now, if you were only gaming I’d say 9900k is best choice.
the amd r9 is also gonna be vastly superior for your rendering.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
3950X costs more, can be hard to find, when found is often overpriced, and is overkill for the large majority of people. The 3900X is a good 9900K alternative around the same price, it can sometimes be hard to find too tho AFAIK.
A 9900K/9900KS is better for gaming (especially once OCed and tweaked properly), and still damn good in multicore stuff. The 3900X is almost as good in games, and extremely good in multicore stuff, the Ryzens typically do a little better than Intel chips at the same core counts in that, and the 3900X has a whole 4c/8t more than the 9900K. Really depends on personal preference and what the bulk of your workload is, both are excellent CPUs at around the same price point.
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
I haven't really explored AMD options. I just looked for both CPUs suggested by @Windoors on my country's biggest distributer's website and 3900x is out of stock and 3950x is not even listed. So getting them might be an issue. But will see if they become available. Thank you.
2 hours ago, boggy77 said:
Hey man, thanks a lot, I appreciate the time you put into this. I searched for the components you changed with my local distributor but seems like some of them are out of stock or not listed. I should have stated the limitations of my country's distributor. Will try to find them somewhere else.
What country are you from?
Mexico, so yeah, not all products ship here or some launches are delayed. These are the 3 largest stores (with best reputation): https://www.cyberpuerta.mx/ https://ddtech.mx/ https://www.orbitalstore.mx/
By the way, you can build a beast in that budget...
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($493.84 @ B&H)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  ($88.99 @ SuperBiiz)
Motherboard: Asus PRIME X570-P ATX AM4 Motherboard  ($153.98 @ Newegg)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory  ($74.99 @ Newegg)
Storage: HP EX920 1 TB M.2-2280 NVME Solid State Drive  ($114.99 @ Newegg)
Storage: Hitachi Ultrastar 2 TB 3.5" 7200RPM Internal Hard Drive  ($34.95 @ Amazon)
Video Card: EVGA GeForce RTX 2080 Ti 11 GB XC ULTRA GAMING Video Card  ($1099.99 @ Newegg)
Case: Fractal Design Meshify C ATX Mid Tower Case  ($89.99 @ Walmart)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply  ($84.98 @ Newegg)
Monitor: Samsung C27JG56 27.0" 2560x1440 144 Hz Monitor  ($269.99 @ Amazon)
Total: $2506.69
Generated by PCPartPicker 2019-12-18 13:15 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
Total: $2506.69
Thanks a lot, I actually found some of these components with my local distributor. Looks like I'm going AMD and something similar to this. Really appreciate your help guys.
Post what you want to go for, maybe we have suggestions
In terms of what I want to use it for: Mostly gaming/streaming (AAA FPSs, hopefully Halo Infinite), 3D Modeling (ZBrush), Illustration (Photoshop). So a 1440p monitor with good color accuracy and brightness is important.
In terms of looks: Not really interested in RGB but I really like the look of the NZXT Kraken X62 Rev 2 98, and I want to maintain a white/black color scheme. The thing is that I already bought the NZXT H510i case and can't return it (it's the only component I bought so far).
Other than the case I'm pretty open for suggestions.
These are the stores where I can get my components: https://www.cyberpuerta.mx/ https://ddtech.mx/ https://www.orbitalstore.mx/ and amazon.com.mx
