Sound Card Recommendations ~ $30
Solved by Metallus97,
13 minutes ago, Person_x said:Do you think a USB sound card would be better suited for me?
The only reason I'm opting for a PCI one is because I hear some USB versions have some kind of weird hissing or they stop working after some amount of time. Thank you for your reply btw.
I think that doesn’t matter with your use case. Idd get internal for the tidiness. More space and less cables on your desk .
Some ultra cheapo USB sound cards have this problem, but at the 30$ range not anymore
