New Build, First build, won't power on
Solved by PsionX,
It's Alive!
just had to reseat the GPU and it now seems to be working. Just have to get it set up and install windows.
a lesson perhaps to be added to the sticky, check the powerbutton header pins carefully, sometimes they are in a large block and it is easy to pin on the wrong ones.
Featured Topics
GoStormPlays ·
Posted in WHALE LAN1 -
GoStormPlays ·
Posted in General Discussion5 -
9
jordan_wills ·
Posted in New Builds and Planning1 -
5
xJDL ·
Posted in Troubleshooting1 -
Marie Rose ·
Posted in Power Supplies12 -
8
