Hey y'all,
Looking to upgrade to the Ryzen 5 3600 this holiday season. I currently have an i7 4790k, ASUS Z87k motherboard, and 16GB Corsair Vengeance DDR3 RAM. With a new CPU I will obviously need a new motherboard and want to upgrade to DDR4 RAM as well. What motherboard and RAM would you recommend I buy? If at all possible, 32GB of RAM would be sick, but cool with staying at 16GB. Would like to keep the total for CPU, MB and RAM around $350 or less. Can stretch slightly if it really makes sense to spend a bit more for a worthwhile upgrade. Whatcha got for me?
https://linustechtips.com/topic/1132791-ryzen-5-3600-build-help/
You got a cooler you want to recycle too?  Does it have am4 mounts?
Motherboard choice
msi b450 tomahawk max                 $114
support out of the box for 3rd gen ryzen
this board is better then the rog strix b450 f gaming
ram all you need is 2x8gb, the viper steel is a solid choice in 3400 or 3600 speed as its cheap and good b-die ram
cpu can be 2600 or 3600 depending on your wallet
msi has a good bios usability, tied with evga, gb
asus is a bit down
ASUS Tuf Gaming X570 Plus         $160
wifi, solid vrm, good heatsink, t/s leads
real tek lan
MSI B450 I Gaming Plus AC                          $120
maybe 3900x/3950x depends on airflow
60A power stages, 6 phase vrm
2 minutes ago, amdorintel said:
Motherboard choice
So you are recommending not get the ROG B450? I have always had great experience with ASUS. And really not worth it for 32GB of RAM? Is the $70~ price difference worth dropping down to 2600?
If you drop your cpu you don’t need the max bit anymore.  Still wondering about the cooler.  The difference between the 3600 and the 3600x is a decent stock cooler
and probably the x is better binned
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($189.99 @ Walmart)
Motherboard: MSI B450 Gaming Plus MAX ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($52.99 @ Amazon)
Total: $342.97
Generated by PCPartPicker 2019-12-09 16:10 EST-0500
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
Total: $342.97
is 3000 memory good or should I aim for higher?
You could aim for higher if budget allow. I have a 3200MHz kit, (Ripjaws V).
Important thing is to check the QVL for the motherboard, it lists all memory that has been confirmed to work at the advertised speed. I happened to know that this set is on there and within budget but if you stretch the budget by $10 or so you could probably manage 3200MHz.
The whole checking the QVL thing you should always do (at least with Ryzen), not just for this motherboard but also if you decide to get another one.
My System:
