RGB Light Offset
Solved by Bombastinator,
22 minutes ago, Sam.MP4 said:I currently have a Gigabyte B450 Aorus motherboard and one of the RGB lights that has the Aorus logo is a slightly different color. Is there any reason for this? That is the one that is a slightly different color. Is this normal? Is this related to the RGB fusion software? It also only does it at certain colors. For example, it doesn't do it at orange or blue but it does it at pink and white.
One of the lights in your RGB lighting behind that panel is somewhat but not totally faulty. Specifically one of the Rs (red) It is such a small problem it is possible an RMA would be refused, but it is a hard hardware issue and that would be the only way to fix it. It should not affect performance in any way.
