Won't get silence from an AIO, especially a cheap one at that.
Something like a 212 Evo, arctic esports or Gammaxx 400 will do fine
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103799
Just now, miky3921 said:
Oh ok and what about something more expensive then ?
Don't pour money into an AM3 chip. They're inefficient by today's standards, and doing so would be a pretty fair waste of money
Just go with whatever of the ones I sent you there. I added another option, which I'd actually probably go with out of the three.
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103808
ok thank you
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103811
What are your specs and temps?
Have you tried lowering fan or pump speeds?
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103817
2 minutes ago, miky3921 said:
well i wrote wrong topic i accually have an air cooler.temps about 44 idle and 60-65 when gaming games like man of medan
The same questions still apply.
Specs? Have you tried lowering fan speeds?
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103830
6 minutes ago, miky3921 said:
ok so my current cooler is this
and sounds like this acually
Those have been and always will be verified jet engines
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13103890
For more expensive, you're looking at basically any Noctua cooler of the size you think would fit in your future case for your next computer since they will send you a new bracket for future sockets if you keep a copy/picture of your receipt.
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13104921
If you have a week or two to deal with international shipping, the Snowman M-T4 4 pipe, direct contact, CPU cooler on aliexpress is amazing for thermals vs noise.  Its not just the heatsink itself, but if i could find the fan it uses and buy that by itself i would fit my whole case with them, they are cheap, good, chinese noctua's from what i can tell.
this thing
Image result for snowman cpu cooler
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13105714
Yep, the original stock cooler for the 8350 is very noisy.
You should get a new cooler but what's compatible will depend on how much clearance is available.
What case and ram are you using?
Where are you shopping / located?
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13123754
this is my case: Aerocool Cruisestar
and ram:HyperX Fury White 8GB DDR3-1600MHz
i live in greece
i decided to by the gammaxx 400 it will fit in my case.Does it includes thermal paste?
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13128694
Yes, it includes thermal paste and fits in the case. It's generally hard to go wrong with.
There's more clearance than the specs may suggest since it doesn't account for the side panel bump. Here's the 158.5mm tall Hyper 212 Evo in one: https://pcpartpicker.com/b/rgw6Mp
https://linustechtips.com/topic/1131374-silent-cooler/#findComment-13138083
