PSU Switch Sound When PC Turned On/Off
Solved by Spotty,
3 minutes ago, ShadowRanger said:The best way to describe it is like a switch inside the power supply switching on/off accordingly.
It's the sound of a relay switching when you shut down the system. It's normal, they all do it. My RM750x makes the same noise when I shut down the system as well.
Featured Topics
svvkjbe ·
Posted in Graphics Cards1 -
TheDarkLoS ·
Posted in New Builds and Planning2 -
bensinspade ·
Posted in Graphics Cards5 -
CloseTheDoor ·
Posted in New Builds and Planning13 -
1
pchelp ·
Posted in CPUs, Motherboards, and Memory19 -
pontikos ·
Posted in Troubleshooting2 -
12
