You should never use a framerate capper/limiter, just V-Sync for non competitive games and FastSync for competitive games.
Personal Desktop":
Luna, the temporary Desktop:
3 minutes ago, redbread123 said:
i heard it reduces input lag tho
It doesn't, all you'll get is micro-stuttering.
If you're playing a game where you can render more than 240fps considering this is a 240hz monitor you should enable FastSync.
In this case Freesync is pointless.
Personal Desktop":
Nope, it does not. Use FastSync with your framerates uncapped.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
tf is fastsync?
I would hope video cards are better designed then a decade or so back when an online game redid their engine and for the loading screen it a static image but the engine treated it as game to be rendered. As there was nothing really to render, people where seeing FPS in 4-5 digits and a lot of video cards burned up if the user didn't have v-sync turned on before starting the game to keep it from going into those high frame rates.
