Need better cooling... For an HP
flibberdipper
I want my grandma's HP to run ice cold and silent. I need a tower heatsink that will work with it though. It's an FM1 socket (old, but not too slow), and I can put a heatsink in it that is up to 16CM, I believe. And it needs to be able to handle 150 watts of pure processing power without breaking a sweat. And the fan HAS to be 4-pin, otherwise all of the fans will spin at 100% (don't know why). I was thinking about an EVO, but I'm not sure if it will fit (both in the socket and in the 16CM it has in the case, and being able to clear pretty much normal height memory ~1.5CM away).
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (9TB partition for general storage + 2TB partition for dumping ground), 4x 8TB WD White Label/Red (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
The 212 Evo will fit. It's 158mm tall.
HP... not even once. It's by far the worst (apart from their business line). The brand that needs the most repairs, overheats all the time, and has horrible build quality.
Her's actually isn't that bad. Just I don't like it hitting 66C.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
66 C isn't even bad unless those are idle temperatures. There is no need to buy an aftermarket cooler in that case (unless noise is that important to her)
It works with FM1, right? This is the mobo in question, with standard height RAM in both slots.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
In the summer it happily nails 80C. This is the middle of winter. :P
Main rig on profile
VAULT - File Server
OptiPlex 7040M
80c still isn't nowhere near dangerous temperatures. Many laptops hit over 90 when on load... I think you're worrying a bit too much.
Granny worries about it.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Yep. http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
you have a granny that worries about cpu temperatures?
Kinda. Her old one used to overheat a lot in the middle of something.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
once again, like I said 80c is nothing to worry about... at all..
But we're talking an old person, here. They won't budge.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
Slight problem. There's only room for a 140CM cooler. Any more ideas? @WoodenMarker @asickduckie
Main rig on profile
VAULT - File Server
OptiPlex 7040M
low profile fans from noctua and others are about as good as the intel stock coolers temp wise... not recommended at all. Perhaps you could liquid cool an HP computer lol.
If you can find a 92mm AIO for less than $40 USD, be my guest. Have any ideas? It would to clear the RAM though (which the EVO would).
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I was joking :| AIO coolers are usually a lot noisier than air coolers, especially at that type of size...
Lol 140cm. I think you mean 140mm.
PH-TC14CS: http://pcpartpicker.com/part/phanteks-cpu-cooler-phtc14csbk
Eer... Yeah. :P
Main rig on profile
VAULT - File Server
OptiPlex 7040M
