Is there any difference between these same GPU different Card
Hey everyone,
I am currently looking to buy a RX 5700 Xt to upgrade my GPU. But I find different cards with different prices.
I came here to ask you if there is any difference between these two, given the wide $ diference range:
SAPPHIRE PULSE Radeon RX 5700 XT: $409.99
https://www.newegg.com/sapphire-radeon-rx-5700-xt-100416p8gl/p/N82E16814202349
ASRock Radeon RX 5700 XT DirectX 12 RX 5700 XT CHALLENGER: $369.99
https://www.newegg.com/asrock-radeon-rx-5700-xt-rx-5700-xt-challenger-d-8g-oc/p/N82E16814930020
Thanks!
You should probably look at reviews of these cards. Differences can be in cooling, noise, quality of VRMs, stock-overclock, ... then you can decide whether their differences are worth a premium to you. I know the Sapphire one has received a lot of praise in reviews, haven't seen one for the ASRock, so far.
Asrock one cools worse, just as the price suggests. Could still look for the Red Dragon or Gigabyte 3 fan card
Desktop benching:
I just looked the Gigabyte 3 fan, it is $399.99 on newegg. Looks amazing!
I guess I need to make this hard decition.
One has a 20 mhz higher clock. Its all there, you just have to read.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
1 minute ago, Pablo Molina said:
Will that make much of a difference? I´m still new a this.
Not realy.
Just now, Pablo Molina said:
Great thanks!
Enjoy it.
On 11/29/2019 at 3:27 PM, Pablo Molina said:
Hey everyone,
Thanks!
Can’t speak to the pulse but I can speak to the challenger. I just bought tried and returned one. (Couldn’t get it to work with my monitor)
the challenger is a basic 5700xt.  It’s also ugly.  Black with yellow and gold stripes.  I don’t have a case window so I could care less though.  No overclock, no overclockability due to the cooler can’t take it, and it’s not super quiet.  Not super loud either.  It IS an actual 2 slot card rather than the 2.5 slot a lot of marketeers are referring to as “2 slot” now.  It’s not a very long card.  Maybe 4 inches shorter than my gigabyte wind force 970 that I was forced to put back in my machine.
  • 1 month later...
On 1/20/2020 at 7:24 AM, klapstok said:
is the pulse worth it?
I'm about to purchase a Sapphire Radeon RX 5700 XT PULSE here in the NL
It is a beast graphics card.
But you are going to have to invest some time to customize your settings and get to know how the Radeon Software and drivers work.
Its raw performance is excelent for the price.
Watch the reviews.  There are really only three variables with cards of the same design: MHz (higher is usually better) decibel number (lower is arguably better), and price.  The first two don’t vary all that terribly much.  They can be quite expensive though.
On 11/29/2019 at 9:34 PM, Loka said:
I’d go for the cheaper one personally as you can oc in Msi afterburner :)
Not entirely true. Cheaper cards usually have worse cooling, which means they will thermal throttle quicker and there is much less possibility to even oc them.
I’m not saying you have to buy the most expensive but to your research first, also instead of buying cheapest just go slightly higher, like sometimes the difference is $20-30 for much better card
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Even the worst 5700xt (well maybe not the TUF) will perform within margin of error of the other cards, and all can be tweaked to acceptable (well maybe not the TUF) thermals.
What you're paying for is noise and looks, and potentially more thermal headroom for overclocking, which the 5700XT isn't very will known for anyway and there's no guarantee.
I chose the cheapest one (XFX RAWII) and I clock between 1800-2050mhz almost all the time and get decent temperatures with an undervolt and custom fan curve.
It's noisy, but at $369, I didn't feel the other cards were worth the extra $60-100..... For that price I'd just get a 2070 Super. That's my opinion anyway.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
What you're paying for is noise and looks.
