Corsair Void Pro Wireless Headset any good?
Pretty much title, Looking for suggestions for my parents for a present for me, and I need a new mic, due to my current one being dead.
I was going to go with the K60, But my parents said they can spend extra so I saw the Void Pro, Its only 70$ CAD on sale from 120$.
The main issue I see is it falls off peoples head easy, and yeah the mic quality isnt that good, but I dont really care, only talk on discord some times. But i really like the look of it, and its wireless, I love wireless stuff lmao.
@rice guru I see you on this section a lot, so ill give it a shot.
M Y  S T U F F
Ryzen  PC |~|  Ryzen 5 1600 | GTX 1060 6GB | G.SKILL Ripjaws V Series 8GB DDR4 DDR4 2400 x2 |  WD Blue 250GB SSD | Barracuda Pro 2TB  EVGA 650W 80+Gold |
Laptop |~| Legion Y530 | i7-8750H | GTX 1050 Ti 4GB | 16GB DDR4 2666MHz | 128GB SSD | 1 TB Hard Disk Drive, 7200rpm |
Macbook Air |~| 2.2GHz dual-core Intel Core i7 | Intel HD Graphics 6000 | 8GB of 1600MHz  512GB SSD |
Displays |~| AOC G2460VQ6 24" x2|
Keyboard |~| Corsair Gaming K70RGB
Mouse |~| Razer Lancehead Pink RG
Audio |~| HyperX Cloud II Audio-Technica ATH-AD700X
Microphone |~| Audio Technica AT2035
M y  R e v i e w s
Lenovo Y530 Legion Laptop.
More Coming Soon...
https://linustechtips.com/topic/1128839-corsair-void-pro-wireless-headset-any-good/
It's a decent headset.
Go for it.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
I'm not a fan much prefer wired solutions . I'm a sound quality and
comfort before features kind of guy. Seems to be a decent solution and a a pretty good price if u need wireless. but if you care a out sound quality overall this isn't it.
If I really wanted wireless though I would probably go with this as it's tuned a little better. But if you don't have the cash to play with the void pro is probably decent enough.
I am not the least biased guy to ask about this unfortunately.
I am currently using it as my main for gaming. The directional sound on it is better than almost everything I've used in the same price range like the hyperX and etc.
Now here comes the cons, the loose head thing is true for people that likes to shake their head alot for some reason, also the pads aren't leather so you will need to clean them often and not quite as comfy. I bought some aftermarket leather pads to replace the ones that came with it and now its super comfy. Tight fit but it works.
Software wise, it's a real doozy because it can start auto shutting down for no reason and won't go away after a update. Had to send mine in and get a new one from corsair after paying for my own shipping. Sucks that they make you pay for shipping.
